929 akra fit my 954?
Yes any exhaust system or bolt-on from a 929 will fit a 954. The only difference between them is the mounting point on the right passenger rearset. These brackets are slightly different in length between the 929 and 954 so the mounting strap will be in a slightly different location. So make sure whatever exhaust you buy if from a 929 does not have alot of rub marks on the pipe from the mounting strap because once you install it on your 954 they will be visible instead on under the mounting strap. You could always switch these brackets on your bike if you had too.
