900RR Pipe on 954?
Old May 7, 2008 | 09:48 PM
Mikes03954RR's Avatar
Default 900RR Pipe on 954?
I was woundering if anyone has tried to put a 900rr pipe on a 954. Someone on the forum has a micron F/S that I want but don't know if it will fit on mine. Anyone have any experience with swapping parts like this?
Old May 8, 2008 | 05:50 AM
dscort's Avatar
Default RE: 900RR Pipe on 954?
nope, the 900 collector is flat and in the center, it will hit the oil pan.
Old May 8, 2008 | 10:36 AM
thankx guess I will not buy it
Old May 8, 2008 | 12:01 PM
txsmainevent's Avatar
Hey Mike is ita full system or slip on? Im sure with a little cut and welding you can get a 3/4 to pipe put on the 54 but the heades i think is a no go. If it is a full system you could probaly cut off at the headers, weld the new ones there, make a few more cuts so you get clearance under the oil pan and threw the side of the bike. I believe it can work but you will be doin some chop and cut
Old May 8, 2008 | 05:49 PM
It's just a bolt on. Is is dueable?
Old May 9, 2008 | 05:59 PM
pimpin what do you think will it work?
noerenstin
Jun 7, 2010 02:09 PM
draymond31
Aug 14, 2009 07:43 PM
