2003 Honda 954
Old May 31, 2017 | 08:12 PM
CBR9's Avatar
Have had regulator issues.
Honda ones usally have been updated with a bigger heat sink.
That said, checking connection problems and cleaning and lubing with dialectic grease helps.
Also lubing back of regulator will help transfer heat in stock location .
Old May 31, 2017 | 08:26 PM
Edgardj's Avatar
Lubing back regulator with what?
Old May 31, 2017 | 09:21 PM
CBR9's Avatar
Dielectric grease.
Old May 31, 2017 | 10:01 PM
Edgardj's Avatar
Dielectric grease.
Ok.Thank you.And what you think about a cooling fan too.
Old Jun 8, 2017 | 09:16 AM
Edgardj's Avatar
Originally Posted by 74demon
I don't recommend using aftermarket. They cost less, but are hit or miss with the quality. I see threads here daily about failure of new aftermarket charging parts. Honda did have problems with their early regulators, but the one you have on your bike is a good design and works. I use the OE parts (I just got a set from partzilla and will be spending my Saturday installing them) and forget about them for 40k miles or so. It's worth spending a little bit more for quality and only having to deal with repairing it once.
If OE is not a option, go with whichever one has the better return policy.
Hi.My Honda 954 hard to start when cold.After it fires and get warm she works good.Stop engine starts again good.The issue is when cold.What could be the problem?
Old Jun 8, 2017 | 10:27 AM
CaBaRet's Avatar
Maybe take a look at your wax unit, or starter valve Sync
Old Jun 9, 2017 | 11:59 AM
Edgardj's Avatar
Hi.Other problema with Honda 954.Hard to start cold.Have to start long two three times.When she fires and get warm stop engine and starts again good with no problem.The issue is when cold.What you think could be the problem.At this moment have not make any inspection.What you sugest.
Old Jun 9, 2017 | 12:38 PM
74demon's Avatar
Could be a number of things. Coolant sensor maybe?
Old Jun 11, 2017 | 02:53 PM
Edgardj's Avatar
Fix the problem.Starter valves close. The adjustment for starter valves is the flexible bolt on the left side of the moto.I tough that bolt was for the adjustment of throttle. But really not.That bolt close and open starter valves.
dustinj
Nov 7, 2010 12:17 AM
driber
Oct 6, 2006 09:39 PM
