2003 Honda 954
Hi.Any help would appreciate. I have a 2003 Honda 954 with charging problems. I got the Haynes repair manual that show me how to check the alternator.(0.1 to 1.0 Homs) are the values for each terminal coming from the alternator.Make the test 0.6 are the three readings and there's no continuity from each terminal to ground.At this point a think is OK.But the manual did not have data to inspect the voltage regulator itself.How could I test this voltage regulator with a multimeter?What is the correct way to check the AC output of the alternator?
Do a continuity check between the cables. Likewise the r/r itself. Think you might find your issue there. From what I remember ( and I have definitely been wrong in the past) I think, remember think, there should be no continuity between cables but my two of my r/r pins
actually did........new r/r and alls good. Should mention, have you've tested your battery output unloaded/starting/ running then loaded ? |
If the stator and battery test good, then the R?R is bad.
Just replace the stator and regulator as a set. That way you will be good to go for a while. If you replace just one, the other will go bad and could take out the newer one. You will be constantly having charging issues and reliability goes out the window. Do them both and be done with it. |
Originally Posted by 74demon
(Post 1304505)
Just replace the stator and regulator as a set. That way you will be good to go for a while. If you replace just one, the other will go bad and could take out the newer one. You will be constantly having charging issues and reliability goes out the window. Do them both and be done with it. Is very simple I do the test and got it,one diode faulty.Only difference is the voltage regulator he use on video is 5 wire,3 to stator one positive,one negative.CBR 954 is 8 wires,3 to stator 2 positive 2 negative 1 to ECM.Don't going to explain now how I do the text,but if someone want it I'll do.The question is if the stator is good in specs why buy other? |
Originally Posted by Edgardj
(Post 1304516)
I have seen on YouTube from Roadstercycle.com a video to check r/r with a multimeter
(Post 1304516)
Originally Posted by CaBaRet
(Post 1304524)
Hi, but are you sure the stator is good ?, have you done an AC output check on the stator with the engine running
(Post 1304525)
Why buy both? Because it will fail fairly soon after you get the new regulator. Leaving you dead in the water. When it does fail, the is a good chance that the short to ground will take out the new regulator. If you don't want to do both and have a solid charging system, then don't. Just don't say that you weren't warned.
(Post 1304530)
What aftermarket stator you recommend to me Ricks,Rmstator,Caltric or Electrosport.
If OE is not a option, go with whichever one has the better return policy. |
Fix
(Post 1304484)
