2003 954 boggs when I hit the throttle.
i bought a 2003 954 that had sit for about a year with bad gas in it. it has a bolt on arkopovic exhaust and a power comander on it. i changed the plugs and drained the gas. I added "sea foam" fuel tratment to the new gas. but heres the proble, when i first got it going and on the first to rides it would not go over 7000 rpm's, and would bog right down if i slapped on the throttle. now a few more rides into it, it has gotten even worse and it wont go over 5000 rpm's now. i'm wondering if this is a power commander issue or if the injectors are gummed up, or a fuel pressure regulator problem. ANY IDEAS????????????
right.. i understand that. what i meant was, what could've cause that so quickly?
