2003 954 boggs when I hit the throttle.
i bought a 2003 954 that had sit for about a year with bad gas in it. it has a bolt on arkopovic exhaust and a power comander on it. i changed the plugs and drained the gas. I added "sea foam" fuel tratment to the new gas. but heres the proble, when i first got it going and on the first to rides it would not go over 7000 rpm's, and would bog right down if i slapped on the throttle. now a few more rides into it, it has gotten even worse and it wont go over 5000 rpm's now. i'm wondering if this is a power commander issue or if the injectors are gummed up, or a fuel pressure regulator problem. ANY IDEAS????????????
There is something gummed up in my opinion but,I would also check the spark plugs to see if they got fouled.
just changed the plugs. the dont even hava tank of gas thru them yet. i was thinking that i should just run it and see if it runs it out.... or is this a bad idea?
I know you just replaced the spark plugs but, still check them and see if you fouled them.
ok...if i did. what does that mean?
Originally Posted by geiger1374
(Post 973624)
great idea... thanks
(Post 973644)
Originally Posted by letsride
(Post 973647)
If you fouled them out you won't get the proper spark to ignite the fuel in the cylinder causing the engine to sputter.
Bad left over gas
