Wiring question+pic
Wiring question+pic
Looks like someone cut something out of harness from under the seat. It looks like something was removed. See attached pic. Also where do the 3 yellow wires from the stator cover go? they were cut too. Can someone pleases shed some light on this for me? Thanks. Its a 2000 if that makes a difference
[IMG]local://upfiles/6767/B154103AD8DC4DA9979045FDC3C911FE.jpg[/IMG]
RE: Wiring question+pic
The 3 stator wires have been cut. Also 3 other yellow wires under the grommet in the second pic have been cut also. I havent got the bike running yet. It was bought with a salvage title as a project. I'm just wondering what was stolen/taken off it while it sat @ the auction house. seems to be missing a few things. I do have it turning over.
+1 on the regulator rectifier (3 yellow wires) you should have a box thats bolted to the side of the subframe thats roughly 4inx3in and has fins all over it. if that is missing, they took that frome the bike before you bought it. It will still crank, but you might want to get one of those, and repair/replace the harness. If you figure out what you need, I have an extra harness and an extra rectifier.
The rectifier is still there. Would the 3 wires from the stator connect to the 3 wires coming from the rectifier. The other wires cut as seen in previous pic connect maybe to a pc3 that was removed? I will check if the stator is still in place. I would say it probably is because the wires are there. I'm hoping anyway.
