Timing chain tensioner???
Old Mar 3, 2008 | 07:25 PM
kentuckydiesel's Avatar
Default Timing chain tensioner???
Are these adjustable, or automatic? If automatic, how can I make sure the tensioner is working? I'm getting some engine noise/vibration that I didn't hear before, especially around 4000rpm. Want to make sure I'm not i danger of the timing chain skipping teeth. Thanks, Phillip
Old Mar 3, 2008 | 08:39 PM
mikey1297's Avatar
Default RE: Timing chain tensioner???
its automatic but i cant tell you how to tell if its working sorry
Old Mar 3, 2008 | 08:49 PM
Mine is missing the bolt that goesin the center. Does this affect anything? Thanks, Phillip
Old Mar 3, 2008 | 08:57 PM
mikey1297's Avatar
i would tink that the bolt is nessesary how many miles have you put on the bike like it is?
Old Mar 3, 2008 | 08:58 PM
Nauree's Avatar
my question is where in the motor did the bolt go.
Old Mar 3, 2008 | 09:17 PM
mikey1297's Avatar
it couldnt have went in the motor
Old Mar 3, 2008 | 10:58 PM
as I understand, the bolt is a plug. Correct?
Old Mar 4, 2008 | 06:49 PM
mikey1297's Avatar
i cant remember good enough to tell you for sure but i think you are right
Old Mar 4, 2008 | 07:37 PM
Joker_114th's Avatar
the bolt is a plug under that plug is a spring that pushes a small piston inward.that lil piston has locks etched on it"lil teeth" so it cannot back off,no bolt equals no tension but in most cases the teeth will hold inward unless you depress the lock,my question is'nt where the bolt went,where did that spring go" it must came out like a rocket it's very rigid.by the way nothing can go in the motor.it only goes one way.............
CBRSQUID
Jun 11, 2012 01:58 AM
EVO_FELON
Nov 16, 2005 01:59 PM
02cbrf4i
May 16, 2005 04:21 AM
