Tick noise... valve clearance or .......????
Old May 15, 2021 | 07:39 PM
Bikelife1229's Avatar
Default Tick noise... valve clearance or .......????
So I finally got my 929 running, it’s been a while and I thought it sounded great , however a buddy said it sounds like I might have a loose valve because there is a tick noise. I’m going to try and upload the 25 second video , tell me what you think. And if so, any suggestions on how to pinpoint which valve or do I just got to check them all again. I forgot to mention I just put a full exhaust on, did valve clearance, and thought I put all the proper siZes in , now I’m second guessing myself
File Type: mov
Old May 15, 2021 | 08:53 PM
Check them all, when the engine is cold. Some reason file won't download completely. Will take a listen if it does finish.
Old May 16, 2021 | 05:28 AM
thanks bro. Man I was so happy to have the bike running , and now I got to rip her apart again smh...o well better safe then sorry right? Thanks for the advice bro, idk why it didn’t finish. I’ll check back in later and see .
File Type: mov
Old May 16, 2021 | 11:41 AM
74demon's Avatar
I can't open it either. Did you check the valves already? Are you sure it's not an exhaust leak at the header?
Old May 16, 2021 | 02:22 PM
you know what, it very well could be. I was having that issue before when I first installed the new headers. I used the firegum stuff that came with the exhaust, but it still had a leak. Any suggestions on a quick way to seal it and try to rule it out without having to remove them?
Old May 16, 2021 | 02:48 PM
How about 4 of these ?
https://www.partzilla.com/product/ho...cbf677d04bc125
Old May 17, 2021 | 06:01 AM
I took out the old gaskets and replaced them with the ones that came with the exhaust system. However, this was my first time changing headers , but it seemed fairly simple . Basically replaced them, put the new headers on, torqued it down to spec. But , when I changed my exhaust valve shims, I had removed the camshafts, so when I put them back on I put oil on them to lube them up, I spilled a bit on accident and when I started the bike I noticed I had a leak from the headers and also the little hole under each header pipe. It was leaking oil it looked like. I thought that was because I spilled some in there and it was pushing it out. It was so bad it screwed all the plugs up I had to replace them. Well, I removed the headers , put more fire gun gasket paste on the gaskets and put the header on however I can see maybe 1 or 2 tiny spots it could possibly leak through. Uhhhh brother I’m getting so fed up I’m ready to sell her and get a newer bike. I’m into it so much money I’ll never ever get what I put into it and the way it’s going it seems like it more n more problems
Old May 17, 2021 | 08:14 AM
also , I got another question. Kind of off topic. So I switched my ecu over the winter after troubleshooting crank no start. I got down to either the wire harness or ecu. I replaced both. Bike fired up. However now on my cluster everything works BUT my tach. Any suggestions on what that could be? I really don’t think it would be the ecu if everything else seems to work fine. Then again all the **** that happens with this bike man I just know anymore
Old May 17, 2021 | 05:30 PM
There is essentially 3 possible things for the Tach not working. ECU is bad, wiring connection from ECU to the Tach is bad, or the Tachometer is bad. You need a Peak Voltage tester in order to see the signal between the ECU and Tach. I'd start with checking the connections since those have been messed with.
Old May 17, 2021 | 06:24 PM
wow man. That’s crazy. When my old ecu was in and it was running. It was fine. So this guy sold me a bad ecu probably. I’m going to try my old ecu back I. And see if I got any luck
