Struggling with 929 not running
Old Oct 10, 2017 | 09:35 AM
Ryan Zapko's Avatar
Default Struggling with 929 not running
  • Hello all,
    I have a 2000 929rr that I tracked successfully for years, then stored. I began to revive it as another street project and have recently hit an absolute wall and need help.
    The bike will start, run great for 3 or 4 seconds, then begin to chug gently at first, then it will continue to get worse and worse until it seemingly drowns itself. I cannot ever get the rpm above 4000. Smells and looks from the exhaust to be running rich.
    I have been attempting to trouble shoot and have already accomplished the following with No success...
    -Changed all 4 plugs
    -Changed all 4 coils
    -When it does idle, all 4 downtubes reach equal temp, so I'm guess valves are operating properly
    -New fuel pressure regulator (2 just in case)
    -New fuel pump assembly including filter
    -New oil change, filter, and coolant flush
    -New Intake air temp sensor
    -New fuel injectors
    -Removed and cleaned fuel rail
    -Disconnected and cleaned fuel rail and vaccuum lines
    -New MAP sensor
    -Disconnected PC III and tried to eliminate that as a source of trouble
    The only thing I haven't done yet was replace the wax valve heated by coolant on the underside of the throttle bodies. Not sure if that could be stuck.
    If you have ANY suggestions, I am obviously willing to spend the time and money to get the bike back to running properly. FYI, I pulled codes and nothing relevant seems to be appearing.
    Thanks a million,
    Ryan
    #Spirit of Independence
Old Oct 10, 2017 | 10:37 AM
74demon's Avatar
Have you tried a different ECU?
Old Oct 10, 2017 | 11:05 AM
Ryan Zapko's Avatar
I haven't tried a new ecu yet mostly because theyare ridiculous expensive from the dealer, and hard to insure the qualitu from used providers.
Old Oct 10, 2017 | 11:16 AM
74demon's Avatar
That's always the case with everything.
Do you know anyone else with a 929 that you could borrow the ECU from for 6 minutes?
CBRrider01
May 12, 2010 10:29 PM
volcomrr
Feb 16, 2009 05:23 AM
stuconz
Dec 24, 2008 03:14 AM
Juliet
Jul 27, 2008 04:14 PM
Juliet
Jul 26, 2008 08:24 PM
