stator
Old Aug 23, 2008 | 10:03 PM
seldon929rr's Avatar
Default stator
on a previous post about valve cover gasket someone said it could be the stator pushing ou the valve cover gasket. lately my gauges will flicker and the bike will shutoff but no codes pop up. is it the stator. any help will be appreciated
Old Aug 24, 2008 | 02:42 AM
HAVOC's Avatar
Default RE: stator
i would have your battery tested 1st... then check the wiring around your reg/rec and see if anything is burnt yet... all else fails goto the "general tech" section and at the top you will see a sticky on how to diagnose the charging system and you can find out if its your stator or not
Old Aug 24, 2008 | 12:55 PM
taz929's Avatar
Default RE: stator
FYI...just replaced my stator and regulator for 500 dollars, they also had to replace a section of wiring that was completely distroyed...
Old Aug 24, 2008 | 01:19 PM
HAVOC's Avatar
Default RE: stator
^^ wow you got ripped off ! did you take it to a dealer to do the work ?
regulator just unplugs and take off two bolts. the stator you take off the cover, drain out some oil un plug it plug the new one in and as far as the section of wiring goes its snip snip crimp crimp with the new wire. less then an hour to do everything.
taz learn to do the work yourself you will thank me later
Old Aug 24, 2008 | 01:32 PM
taz929's Avatar
Default RE: stator
Thanks for the info, I thought it was expensive but I had to get it up and running so that I could take care of a ticket.
Old Aug 24, 2008 | 01:55 PM
HAVOC's Avatar
Default RE: stator
sorry didnt mean to come off as a jack *** , now if that included brand new parts from honda plus labor i guess thats not bad but you couldve gotten things for way cheaper and done the work your self but hey live and learn .
Old Aug 24, 2008 | 08:22 PM
GP_RZ's Avatar
Default RE: stator
I had the problem of the stator overheating and causing the oil to boil or steam and the excess pressure would escape by blowing by the valve cover gasket.....and would usually stall....this would only happen at idle, would start back up.....anyways replaced stator and problem went away, running like a charm now.... got the stator form RMstator.com fom Quebec Canada at around $160 canadian delivered to my door with a 1 year warranty.
http://www.fireblades.org/forums/hon...-my-929-a.html
Old Aug 24, 2008 | 09:12 PM
HAVOC's Avatar
Default RE: stator
if your stator is overheating to the point your blowing the gasket you better check the rest of your components to make sure they aren't either damaged from the stator overheating or the ones causing the damage to the stator.
Old Aug 24, 2008 | 09:18 PM
GP_RZ's Avatar
Default RE: stator
yup all good.....replaced the R/R with a new one and a new battery...all conections are good!
Old Aug 25, 2008 | 09:30 PM
taz929's Avatar
Default RE: stator
No problem. The truth hurts some times. And no it was not done by the Honda shop and I think I was screwed. For know on I will make sure that I do the work myself. At least now I know where to go to get some answers.
