stator
RE: stator
i would have your battery tested 1st... then check the wiring around your reg/rec and see if anything is burnt yet... all else fails goto the "general tech" section and at the top you will see a sticky on how to diagnose the charging system and you can find out if its your stator or not
RE: stator
^^ wow you got ripped off ! did you take it to a dealer to do the work ?
regulator just unplugs and take off two bolts. the stator you take off the cover, drain out some oil un plug it plug the new one in and as far as the section of wiring goes its snip snip crimp crimp with the new wire. less then an hour to do everything.
taz learn to do the work yourself you will thank me later
RE: stator
I had the problem of the stator overheating and causing the oil to boil or steam and the excess pressure would escape by blowing by the valve cover gasket.....and would usually stall....this would only happen at idle, would start back up.....anyways replaced stator and problem went away, running like a charm now.... got the stator form RMstator.com fom Quebec Canada at around $160 canadian delivered to my door with a 1 year warranty.
http://www.fireblades.org/forums/hon...-my-929-a.html
