Snapped bolt clutch cover
Old Apr 21, 2020 | 04:20 AM
Daz Tank's Avatar
Default Snapped bolt clutch cover
I've snapped a bolt on the outer casing. Is it gonna be a problem?
Old Apr 21, 2020 | 09:56 AM
74demon's Avatar
Is it on top or bottom?
Old Apr 21, 2020 | 03:22 PM
Daz Tank's Avatar
No it's one of the outer casing bolts. Will it effect the seal?
Old Apr 21, 2020 | 03:37 PM
74demon's Avatar
It might. Is it a top bolt or a bottom one?
Old Apr 21, 2020 | 03:43 PM
Daz Tank's Avatar
Bottom one. Should I take the crankcase off and try remove what's left of the bolt or just leave it as is and hope for the best?
Old Apr 21, 2020 | 03:52 PM
74demon's Avatar
First I would see if its loose enough in the hole to try to back it out. If it's not, I would put some sealant on the area and see if it leaks. If the cover is already back on, just try it and hopefully it seals. You have nothing to lose at this point.
Broken bolt extraction can be easy or become a nightmare if you don't know what your doing.
mdowney421
May 17, 2012 04:50 PM
Craig84
Apr 15, 2012 08:18 AM
dafizuck
F2 Tech
May 18, 2010 12:56 AM
El Tigre
Aug 26, 2007 08:12 PM
