Shift Light?
Old Apr 3, 2009 | 08:05 AM
packdog's Avatar
Cool Shift Light?
Any body build a Shift light? buy a shift light? Ideas for how to build one?
Old Apr 6, 2009 | 06:21 AM
vwmaniacvr6's Avatar
If you're going to build one yourself you need to scope the rpm signal to the gauges. It will be a square wave of some kind, just figure out what voltage it is. The you could hook a signal generator to your tach and watch how it reacts to different frequencies. Find the frequency that corresponds to the rpm you want to shift at and build a circuit that sends a voltage above that frequency. Use it to trigger a light and you're all set. Otherwise most stand-alone shift lights cost $80-$200.
Old Apr 6, 2009 | 07:37 AM
packdog's Avatar
Seeing as i don't have a scope, could i find good use for one in the future, or should i put the money towards a stand alone shift light? I'd love to take on a project like this cause it'd def be a challenge, but I could see a scope costing $80-$200 and if i never use it again, well, that'd be kinda silly.
Old Apr 6, 2009 | 08:07 AM
packdog's Avatar
looking around I've found this one http://www.ecliptech.com.au/main_win_sep06.html. looks pretty fancy, a bit more than i was expecting which was really just a single LED in a barrel (like this one http://www.harlan-engineering.com/st...hiftlight.html). Any thoughts? there is a pic with one installed on a 929
Old Apr 6, 2009 | 03:46 PM
jw0rd's Avatar
get an Acumen -> http://www.acumen-electronics.co.uk/...___Shift_light
Old Apr 7, 2009 | 08:25 AM
packdog's Avatar
thanks, but again, it seems a bit busy and distracting. I think i'm going to go with the harlan, which I plan to use as an idiot light: "HEY, you're getting to red line! shift dummy" :-)
Old Apr 7, 2009 | 02:49 PM
If you want to make it yourself these are cheap:
http://store.autospeed.com/Items/14447
All it does it put a voltage out, so you would need to source you're own LED array. In US dollars it is around $22, but who knows how much shipping from Australia is. That $50 light might be worth it since it's ready to go and looks good.
hilclmr
Jan 11, 2022 06:12 PM
ganzey
Jul 31, 2012 02:09 PM
Flamed900RR
Jun 24, 2007 10:32 PM
mr tone
Oct 11, 2006 02:15 PM
F4i_Rich
Aug 3, 2005 03:15 AM
