send me your fuel maps :)
Old Aug 2, 2007 | 09:57 PM
grim129's Avatar
Default send me your fuel maps :)
hey guys im still trrying to get my bike to stop runing soo much gas
i would like to try and use some of your guys maps see if i can get her ro work
so if you guys could email me your maps that would be a lot of help
grim129@gmail.com <---------------------------
my bike is:
2001 Honda CBR929 California model (NO o2 pluged in! )
power commander 3 usb
Yoshimura full system
K&N air filter
Old Aug 2, 2007 | 11:02 PM
ApexClipper's Avatar
Default RE: send me your fuel maps :)
Dude, you probably should run your bike on a dyno at the local shop and see what's up but if you want to try my map you can give it a spin. Similar mods on mine, Cal model with full Arata and K&N.
To attach it here I've renamed it as a .TXT file, just rename it with a .MAP extension.Good luck.
Old Aug 2, 2007 | 11:34 PM
grim129's Avatar
ya thats what i want to doo but i cant get it to the shop wth out killing all the plugs in it seeing how its runing soo much gas
can you email that map yo mee it does not seem to be working
Old Aug 4, 2007 | 07:05 PM
luke_comans's Avatar
if you goto http://www.powercommander.com/powerc...42&yr=2001and look at the map labeled m104-029 i think you will find what your looking for.
Old Aug 4, 2007 | 08:00 PM
HAVOC's Avatar
im wondering if you bought the bike with the PC already installed and your trying to tweak something that is already present or did you upload a map and you dont like how it feels so you want to try different maps ?
also are you running a o2 sensor eliminator ? and what rich/lean settings are you at ? if you hold down all 3 buttons when your bike is off, then start the bike and let go of the buttons, then press which mode you want to tune(low,mid,high) and if you press it once it will go up a level (richness) and if you hold it down it will move down a level (lean) ... when i looked @ mine i found out that all 3 levels were set to maximum richness
oldnotslow
Sep 16, 2010 09:12 PM
devldog2005
Nov 4, 2008 05:38 PM
phsycleRR
Sep 17, 2007 09:36 PM
The Anti-Dj
Aug 29, 2006 12:42 AM
600Grr
Jul 16, 2005 07:25 AM
