Scotts Damper Service
If you can manually move the piston, it needs serviced. If it is adjustable, set it to the medium setting (middle) and you should just be able to move it with your hands.
In all honesty, unless it's just trashed, it should still work wonders. Install it, come hard out of some corners and see what you think. If you get any kind of shake, adjust it (if so equipped). Try again. If it still has play no matter what the setting, have it serviced.
P.S. Yours is junk, I'll buyit for $25...
![Wink](https://cbrforum.com/forum/images/smilies/wink.gif)
