projector 929
Oh, I NEED to know how exactly you did that! where did you get the projector? how did you open the headlight unit? how did you fasten the projector? please post the step by step because i want to do this kind of upgrade in the worst way due to the fact that the stock low beams are terrible.
the projectors i got from pick a part some hondas have then infinity j30 dawoo laganza and so on you just have to look these projectors use 9006 bulbs but the cool thing is to go HID.as for taking the lens off the light i didnt take any pics showing how you do this but its done with a heat gun and a knife you heat the seem and priy the lense off the housing.then you pull the inside of the light out when you have it out you need to hook the light to a 12volt power source and set the light on a flat surface and shine the beam on the wall take a marker and mark the floor where the light is sitting and mark the wall at the highth and center of the beam because after you put the projector in your going to put the light on the marks on the floor and ajust the beam to the marks on the wall.i used a hole saw to cut the hole in the light i used a 2 1/4 and drilled 3 holes one on the bottom and 1 on each side put the projector ajust the beam tighten the bolts and then sillicone all around the in side and let it dry.when putting the light back together you have to heat the seem and the glue and put it back together and to be sure it water tite silicone all the way around the seem thats it.i hope this helps you guys for more info go here
http://www.youtube.com/watch?v=imIiglkq7HA
