which plugs to run
Old Nov 24, 2007 | 02:51 PM
Ripper44's Avatar
Default which plugs to run
Wondering if any one can tell me if they have ran iridium plugs and if they noticed any differance from the oem part. What is the best plug to run ngk,denso?? any info is appreiciated thanks fellas
Old Nov 24, 2007 | 02:53 PM
Lord Jersey's Avatar
Retired Admin, January 2008 ROTM, Lord of Neon & L.E.D.s
Default RE: which plugs to run
I prefer the NGKs. I can get them cheaper from work too, so that does help. Lol. I think they run better than some others out there though.
LJ
Old Nov 24, 2007 | 03:59 PM
gixxereater's Avatar
The only way you will notice ANY power improvement is if your current ones aren't firing at all. The IR plugs do nothing for performance. Some say they could wheelie in 6th gear after they put them in but I think they may have been drunk when they rode it. LOL.
I use IR plugs so I likely wont have to change them again while I own any bike and use NGK when I do. Never had a misfire yet. Other than that, you wont notice a difference.
Old Nov 25, 2007 | 01:07 AM
lexiconby's Avatar
Was this a trick question The OEM plug for the 929RR is the IR plugs.Part number IUH27 or IUH27D, I forget.
http://www.globaldenso.com/PLUG/plus/features.html
http://www.globaldenso.com/PLUG/qa/iridium/qa_1.html
Old Nov 25, 2007 | 01:33 AM
lexiconby's Avatar
I really like these plugs on my 929RR.
Old Nov 25, 2007 | 04:47 PM
Ripper44's Avatar
Not a trick question this is the first time i've been this deep into the bike just wanted to make sure i put the best possable product in when i replace them thats all thanks for the input.
Old Nov 25, 2007 | 11:28 PM
lexiconby's Avatar
NGK IX or DENSO Iridium Power are pretty much comparable. the only difference i think is that NGK's smallest electrode is 0.6mm while DENSO uses a 0.4mm electrode diameter.DENSO has the tapered cut and u-groove (could be DENSO hype) but iridium is an absolute must. iridium can handle heat 700C above platinum.the higher compression ratio, the hotter the plug tip can become. the NGK iridium plug might provide a longer life because it's a larger diameter plug (more electrode to wear down). however, the 0.4mm size on the DENSO reduces misfires becauseit doesn't need the same amount of voltage to create the spark. note that iridium plugs do not provide a longer life than platinum, it's strictly about having the best spark under all stress conditions.
Old Nov 27, 2007 | 12:08 PM
sixs929's Avatar
Put NGKs in mine a couple of thousand miles ago. So far so good.
VeryMotley
Dec 2, 2009 03:15 PM
BigNate354
Jul 30, 2008 03:41 PM
iroc_254u
Apr 9, 2008 05:37 AM
95HondaCBRF3
Jun 11, 2007 01:58 PM
bigboycbr
Nov 10, 2005 06:32 PM
