After running it for about 20 min temp got up to over 270, shut it down, seem the fan isn’t turning on, I got the fairings off but not sure what I’m looking for, from what I can find in the manual I think I’m missing the fan motor switch connector, but I can’t seem to find it. Is this the issue? Pics included. Thanks for any help
Look at fan itself. Wire connector plugged into fan has 2-wires
1. one wire goes to fusebox and should have power full-time
2. second wire goes to that thermo-switch. Which grounds fan circuit at proper temperature and allows current to flow from fusebox, through fan, then to ground.
I figured out the wires that come from the fan the previous owner had connected together, I pulled them apart and connected them according to a manual I found online (pics below). I let the bike idle, after about 7 minutes temp got up to 240 and the fan still didn’t come on so I shut it off. I’m not the most mechanically inclined but if I could figure this out without a shop I’d like to. Any other ideas on what to check? Has fresh oil change and coolant flush.
First photo is completely wrong with nothing connected to fan-thermoswitch. That 2nd photo looks better.
Unplug that fan-connector and look at wires going to harness:
1. blk/blu wire should go harness and then to FAN fuse. It should have +12v full-time when key is ON
2a. grn wire goes to chassis-ground upstream.
2b. grn wire connects to blk wire downstream at fan and goes to ring-connector to ground radiator
