neutral switch/light
Old Mar 10, 2009 | 11:15 PM
your_mom's Avatar
Default neutral switch/light
so my neutral light doesnt come on any more and my bike wont start unless the clutch is pulled in and the kickstand is up is their some kind of sensor or what?
any help
Old Mar 13, 2009 | 08:55 AM
packdog's Avatar
the short answer is yes, there is a sensor. if you have the bike in gear and put the kickstand down you'll kill the engine, that is normal. so, obviously, the bike thinks it's still in gear even though you have the tranny in N. there is a sensor that tells the ecm the bike is in neutral, unfortunately i don't know where that sensor is located, but I'm sure I (or you) can find it in the manual. could be simply a broken wire, you'll have to do some searching with a test light/voltmeter. the manual can be downloaded from the post at the top of the 929 forum
Old Mar 13, 2009 | 09:17 AM
packdog's Avatar
follow the shifter linkage into the motor, somewhere above that should be some wires. that'll be your neutral switch.
Old Mar 14, 2009 | 07:32 PM
your_mom's Avatar
thanks man that helps alot
Jamied
Sep 14, 2013 08:55 PM
Tatt
Jul 16, 2012 03:42 PM
Spyro
Apr 16, 2012 05:33 AM
coldflood
Aug 5, 2011 06:05 PM
entity-unknown
Aug 27, 2009 06:50 PM
