need a Regulator rectifier
Old Feb 5, 2008 | 09:16 AM
shrek's Avatar
Default need a Regulator rectifier
i need a Regulator rectifier does anyone have an extra?
Old Feb 5, 2008 | 09:50 AM
95HondaCBRF3's Avatar
Default RE: need a Regulator rectifier
www.BikeBandit.com thats where ibought mine from.
Old Feb 5, 2008 | 09:58 AM
SurfnSCal's Avatar
i have a reg/rec at work for a cbr600rr i think an 03. i'm not sure if it is the same part #. If i remember i'll see if that part is the same with your bike's Also check the condition of your battery. If you are running a dead battery or really low voltage one that can hurt the reg and cause it to burn up and fail. So get a charger and charge it up. Then disconnect and let it sit for about an hour to let the surface charge go away. Then take your reading! 12.5 i would recommend replacing, if it is a ytz10s they hover at 12.8 fully charged. If you have access to a tester thats great, or maybe your local dealership will just test a loose battery for you no charge. But if they want to charge you...just take your voltage reading
KRUSHER F3
Apr 14, 2019 08:56 AM
paul_schmd
May 8, 2010 11:09 PM
chrisrc
CBR1000F Wanted / Swap
Apr 19, 2010 03:03 AM
cbrsixpack
The Hurricane Saloon
18
Jan 9, 2010 02:18 PM
jeffrimerman
Dec 22, 2006 03:53 AM
