how to tell if ecm is bad on 00 929
Easy way is to put it into another bike and see if its doing the same thing.
If you dont have a spare 929 kickin around, then you would need to figure out what it is that isnt happening and weather or not that is controlled by the ECU.
In short, the ECU controls the Following.
Ignition Timing/Advance
Fuel Delivery through the injectors, injector pulses
And It outputs the Tach signal to the instrument cluster.
It gets its inputs from sensors on the bike, TPS, ECT, Ignition pulse Generator, Cam position sensor,Map sensor, IAT Sensor, and a few others.
If any of these fail, you get a trouble code, or a no start condition, or both.
Raptor5150
Oct 22, 2012 12:45 PM
