HELP!!!!!! trunk lock problems
Old Apr 26, 2007 | 01:18 AM
95HondaCBRF3's Avatar
Default HELP!!!!!! trunk lock problems
ok in the hot bodies undertail how did everyone get that trunk lock working properly this thang is the biggest pain in the A$$!!!!! almost a waste of money lol so if someone had a good idea that actually worked with the lock let me know thanks!
Old Apr 26, 2007 | 12:32 PM
johndoe's Avatar
Default RE: HELP!!!!!! trunk lock problems
what exactly do u mean its not working properly??? there should be a hole cut out in the undertail for the lock. your going to have to take apart the lock and flip the arm around.
Old Apr 26, 2007 | 12:50 PM
you mean i have to take the arm off of the lock and flip it over so instead of it pointing up it will point down or just stick the lock in as is the instruction that came with the undertail were messed up hardly legable thanks for your help
Old Apr 26, 2007 | 12:52 PM
when i turn the key with the lock the way it is it moves the latch a little but not enough to open the seat
Old Apr 26, 2007 | 01:55 PM
Triax's Avatar
Turn the lock alittle to the right
Old Apr 27, 2007 | 09:57 AM
FIXED IT!!!! i just flipped the lock arm around and it works perfect now its not catching anymore thanks for your guys help it looks really nice!
Old Apr 28, 2007 | 10:37 AM
zeke7681's Avatar
yeah i had the same problem with mine kind of a pain in the *** at first
Old Sep 11, 2007 | 07:02 AM
BigMike0147's Avatar
Does anyone have any pics of this?? I am having the same problem. I think my trunk lock wants to spin away from the latch when I try to unlock it. Also, how close to the edge of the undertail (tail light) did everyone mount their license plate (any pics)?? Thanks for any help!
Old Sep 11, 2007 | 08:24 AM
Lord Jersey's Avatar
Retired Admin, January 2008 ROTM, Lord of Neon & L.E.D.s
I am having the same problem with mine. I think the person before me put a zip tie on it to hold it in all the way. I took the zip off and now I can't get it to stay in there. It wants to fall out of the hole if I unlock it too fast. Pictures would be nice if anyone has them.
LJ
Old Sep 11, 2007 | 09:27 AM
ill take some pics of it when i get off work but is the locking clip still there it is a metal clip like in a car door that holds the lock cylinder in place. also on the top of the lock cylinder in a lock arm if you take off the little circlip on the top of it make sure everything is still in the bike when you do this. and you flip over the little arm so it is pointing down it worked great
