Help with mil code
Hi
I have a mil code that stays on bike seems to run fine but I can't tell if its a 35 or a 1,25. I noticed there seemed like a bit of a long pause between the first flash and the second flash of the longer flashes. I will take a video later and try and up load it thanks for the help
There is no code 25.
35 points to the EGCV servo. That's the thing that all the cables from the airbox and HTEV on the exhaust go to.
1 or 2 are for the map sensor, more likely its unplugged.
There is no 5, but 7 is for the ECT.
All of those items would cause running issues. Recheck your codes and be sure what number you have so we can point you in the right direction.
Have you recently done any work to it, like under the tank?
Hi thanks for the reply. So there is no code 25? All I do is count long flashes followed by short flashes for the number correct? So it is a code 35 then. Would this code sound like a running fuel pump when in the on position but not started?
