heli coil
Old Apr 26, 2008 | 01:28 PM
goldenboy929's Avatar
Default heli coil
as you all know it seems like i have had nothing but problems with my bike so just as i got done replacing the fork seals and bushings i take my bike out the next day for a ride and i was on the highway not even going fast nor beating on it at all and i blew a spark plug out... so i got it home and releaized thats what the problem was i tore the gas tank off and air box to realize it didnt just back out i stripped out so now im looking into getting a heli coil put in any one done this or even any recomendations maybe
Old Apr 26, 2008 | 10:02 PM
bravehart's Avatar
Default RE: heli coil
i got a spare cylinder head with cams i was going to get ported and polished i'll sell or trade for, if you use heli coil im not sure how you would keep metal shavings from falling into the cylinder unless you remove the head.
Old Apr 26, 2008 | 10:39 PM
TK954RR's Avatar
Jan 2009 ROTM
To do it properly you are going to need to pull the head off. Heck i dont honestly think even if you wanted to try and cheat you could get a drill in there anyhow with the motor still in the frame.
Old Apr 27, 2008 | 08:19 PM
vwmaniacvr6's Avatar
Ask around a few local machine shops. There is a creepy tool that slips in, then cuts the threads for the coil from the inside out. Keeps the shavings out, but hard to find anyone who owns one.
Another option is to check the cam profile and find the overlap where both the intake and exhaust valves are open. Set the motor inside that angle and blow air through the intake (sealed) while you cut the threads. The shavings will be blown out the exhaust.
Either way is more risky than pulling the head, it depends if you feel the risk is worth the time savings.
Old May 3, 2008 | 03:48 PM
APOSTO's Avatar
I HAVE NOT DONE ONE IN A BIKE BUT I HAVE DONE PLENTY IN FORDS WITH THE 5.4S . I DONT SEE THIER TO BE A PROBLEM ON BIKES. JUST PUT GREASE ON THE TAP IT WILL CATCH ALL OF THE ALUMINUM . JUST TAKE YOUR TIME AND KEEP IT STRAIGHT AND YOU WILL BE FINE . GOOD LUCK.
Hyperblau
Jul 10, 2012 03:56 AM
taelvin
Apr 27, 2011 09:54 AM
brett82
May 13, 2009 02:17 PM
dixieflatline76
Jul 9, 2007 11:41 AM
hobbs51
Feb 18, 2007 10:48 PM
