Headlight issues
Old Aug 17, 2013 | 07:15 PM
Slats Clownin's Avatar
New Member
Default Headlight issues
I have a 2001 929. Im having issues with visibility at night and cant really see past 15-20 feet in front of me. Ive replaced the stator, rectifier, and new battery. ive tried rotating the bulbs in the headlight assembly and till cant get better vision. it wont shine like other bikes. Does anyone have some advice.?
Old Aug 17, 2013 | 11:37 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Did you try the headlight adjustment screws?
honda cbr 929 aim headlight
Old Aug 21, 2013 | 03:31 AM
bucklti's Avatar
Registered Users
Is it a new problem with the bike? Is it a during high beam or low beam or both? The stock headlights on these bikes aren't very bright.
Old Aug 24, 2013 | 12:35 AM
New Member
Default answer
Yes I did. it helped a lil bit. I even changed the stock bulbs to a brighter Bulb and still the same issue.
Old Aug 24, 2013 | 12:42 AM
New Member
Ive had this issue ever since ive had the bike. I tried adjusting the bulbs, I helped a lil bit, even bought new brighter bulbs and still the same issue. I did notice when I only had one light hooked up, it was real bright til I hooked up the others. Then the same issue came back with not being able to see no more than 15 in front of me at night. its worse on low beam. it has to be on high beam to get "ok" visibility.
Old Aug 24, 2013 | 08:24 AM
74demon's Avatar
What is you voltage at the bulb?
nmb1233
Feb 23, 2012 03:18 PM
konaman
Apr 21, 2011 03:05 PM
dailygrind929
Sep 12, 2010 10:00 PM
cjustice11
Jul 15, 2009 10:05 PM
2005RX8
Sep 12, 2008 09:44 PM
