gauge cluster help
Old Jul 15, 2007 | 07:41 AM
JDMonster's Avatar
Default gauge cluster help
How do you set the damn clock, also My temp reads in celcius and I want it back to degree's.
thanks
Old Jul 15, 2007 | 06:19 PM
luke_comans's Avatar
Default RE: gauge cluster help
you have to press both buttons repatedly three times. i think the one that changes it from klm to mph, if you hold it down it changes the temp reading
Old Jul 15, 2007 | 06:48 PM
mark5009's Avatar
For the metric / imperial thing use the right button: one quick hit and something changes -- mph / kph I think , hold it and the other changes C / F. Fiddle and you will get it. The left button is for the trip distance: short stab changes, long erases.
For the clock, I just worked that one out with help from searching past posts. The way it work for me:
+ Hold right and left buttons down (right just before left)
+ This causes one of the clock numbers to flash, hours I think
+ The left button then moves from hours to minutes display
+ The right button will allow you to change the number
+ When you have it set just right, don't ouch anything for about 15s and the clock will stop flashing.
Good luck and hope this helps.
Old Jul 16, 2007 | 07:59 PM
JDMonster's Avatar
ORIGINAL: mark5009
That did it, thanks
Edward Tristram
F2 Tech
Jun 27, 2012 04:20 AM
jestr
Jul 20, 2008 06:40 PM
