gauge cluster help
How do you set the damn clock, also My temp reads in celcius and I want it back to degree's.
thanks |
RE: gauge cluster help
you have to press both buttons repatedly three times. i think the one that changes it from klm to mph, if you hold it down it changes the temp reading
How do you set the damn clock, also My temp reads in celcius and I want it back to degree's. For the clock, I just worked that one out with help from searching past posts. The way it work for me: + Hold right and left buttons down (right just before left) + This causes one of the clock numbers to flash, hours I think + The left button then moves from hours to minutes display + The right button will allow you to change the number + When you have it set just right, don't ouch anything for about 15s and the clock will stop flashing. Good luck and hope this helps. |
ORIGINAL: mark5009 How do you set the damn clock, also My temp reads in celcius and I want it back to degree's. For the clock, I just worked that one out with help from searching past posts. The way it work for me: + Hold right and left buttons down (right just before left) + This causes one of the clock numbers to flash, hours I think + The left button then moves from hours to minutes display + The right button will allow you to change the number + When you have it set just right, don't ouch anything for about 15s and the clock will stop flashing. Good luck and hope this helps. |
