Fuel Pump??
Old Jan 26, 2008 | 10:52 PM
kentuckydiesel's Avatar
Default Fuel Pump??
Will a fuel pump from any of the other models fit my '00 929?
Old Jan 27, 2008 | 03:20 PM
ReSpEcT's Avatar
Default RE: Fuel Pump??
929 and 954 fuel pumps are the exact same....And im sure a few others are the same as well....=-)
Old Jan 27, 2008 | 03:50 PM
HAVOC's Avatar
dude like i mentioned in your other thread your fuel pump might be fine but there are other reasons that will cause the fuel pump not to prime such as the kill switch and the B.A.S (bank angle sensor.. or more commonly refered to as the "tip" over sensor) check these things 1st and im sure you will find the problem within there
Old Jan 27, 2008 | 05:37 PM
the pump is definately bad, I pulled it today and tested it by itself, no go.
Honda wants like $370.....uh, no thanks. after a little research, found out our pumps are of the same series made by denso that was used in the mid 90's mitsubishi 3000gt, but the mitsu has a higher flow rate. sounds like an upgrade to me! picked one up at advance today for $130. I'll let you all know how it works. -Phillip
Old Jan 28, 2008 | 12:43 PM
pawnman's Avatar
if that doesn't work for you i have a goodlow mile pump i'll sale for $50.00 plus the shipping
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
