FI light on from pC3R
Old May 9, 2006 | 02:04 AM
birde's Avatar
Default FI light on from pC3R
i hooked up my powercommanderIIIr and now my Fi light came on. any suggestions?
Old May 9, 2006 | 11:49 AM
Y2K929RR's Avatar
Default RE: FI light on from pC3R
Make sure the connections are in the right place and that you didn't pull a wire or plug by accident when you installed it. Also check if you have the right MAP file loaded.
Old May 9, 2006 | 03:10 PM
birde's Avatar
right now the bike is all stock i dont have any map on it, my air filter is in today. is it bad if that lights on and i ride it
Old May 10, 2006 | 12:30 AM
clean929's Avatar
even if the bike is stock you still need to down load map 0001 that the map for a stock 929rr. that should stop the fi light from coming on if you did connect the plugs correctly.
the plug will be on the right side right under the gas tank.
Old May 10, 2006 | 03:51 PM
birde's Avatar
the kid that hooked it up forgot to plug a main wire back in, he accidently unplugged it.. is there anymaps for stock pipe plus k&n filter
Old May 10, 2006 | 04:41 PM
ibkevman's Avatar
go to powercommander.com and look. they have a lot of maps to choose from
Old May 10, 2006 | 05:22 PM
birde's Avatar
everymap that was on that site came on my disk i didnt see it on there :/
Old May 16, 2006 | 05:45 PM
erion929's Avatar
i hooked my power commander 3 up on a 2001 929 and every once and a while the FI malfunction light will come on is there something i should look into or just take it 2 the shop and have them fix it?
Old May 17, 2006 | 01:18 PM
ibkevman's Avatar
ORIGINAL: erion929
figure out what the "code" is on the blinking red light in your gauge cluster then check the manual. I'd definitely look into it. I had the idiot light on when I plugged in my pcIII and it was just a bad connection with one of my 3000 sensors.
Old May 17, 2006 | 04:02 PM
birde's Avatar
make sure everything is plugged in
f4iman
May 1, 2008 04:37 PM
shizz
Mar 31, 2008 07:26 PM
StreetPower
Jan 26, 2008 05:15 PM
f3racer
Nov 6, 2007 06:21 AM
