exhaust valve
Old Mar 3, 2008 | 06:59 PM
mikey1297's Avatar
Default exhaust valve
has anyone taken the exhaust valve out and had problems with it?
Old Mar 3, 2008 | 08:59 PM
letsride's Avatar
Default RE: exhaust valve
Yes you can but, you have to install a Hass Eliminator.Gives it freer exhaust flow kind of like a full system exhaust with out the extra expense.
http://cgi.ebay.com/ebaymotors/ws/eB...:IT&ih=004
Old Mar 3, 2008 | 09:05 PM
mikey1297's Avatar
yeah i know about that i am wanting to know if anyone has had any problems with the bike not running right after they did that thanks for the ebay thing though
Old Mar 3, 2008 | 11:20 PM
letsride's Avatar
Well the only problem I had with it was when you use the map they give you I had a small hesitation at around 2500 rpm which I fixed with changing the map settings.
Old Mar 4, 2008 | 05:59 AM
mikey1297's Avatar
did you use a map from the powercommander web site?
Old Mar 4, 2008 | 10:36 PM
letsride's Avatar
No,I used the one that Hass sent me.It was custom for my bike let them know what you have and where you live and they'll send you a map foryou to download.After I took mine to get a dyno run and was told that it was pretty close I was off in the low RPM.Then fixed it with some adjust to the map.
Old Mar 5, 2008 | 05:53 AM
mikey1297's Avatar
is it worth the money?
Old Mar 5, 2008 | 11:03 AM
letsride's Avatar
Well,it's better than a bolt on,I did get a much better throttle response.It's a less expensive way of getting a full exhaust.When it was dynoed I got 129hp and it showed a very steady climb thru out the rpm's.May get it better with some more fine tuning but, my dyno guy said it's probably not going to worth it. $250.00 to get maybe 2-3 more hp.
Shipleymanx
Oct 26, 2013 01:30 PM
K20what
Mar 26, 2009 04:07 PM
r7derek
Oct 25, 2008 01:08 PM
billybob
Jun 24, 2006 01:20 PM
reevesna
Jul 1, 2005 09:14 AM
