exhaust????
Old Aug 16, 2005 | 01:23 AM
929_erion's Avatar
Default exhaust????
I have read so much about this and there are so many different answers and ideas. First of all what is the main function/purpose of the HTEV and how does it work? Also i have read that if you take it off that you will have problems with the bike. Is this true and should i get a full or 3/4 system??
Old Sep 5, 2005 | 03:04 AM
crunchy929's Avatar
Default RE: exhaust????
that valve does alot on a completely stock bike. It basically adds backpressure to your exhaust at low rpm in order to make more power on lower revs, then open up to make less back pressure and more power at high revs. I know for a fact if you just remove the valve you will have problems. It destroys your low end power. The bike will just lug like you wouldnt believe til 5 or 6k rpm. Im not sure how this is effected with a full system but if you get a power commander it will bypass the **** in the computer and make it run properly without the valve. Just dont try to run it without the valve on a stock bike.
Old Sep 8, 2005 | 03:40 AM
929_erion's Avatar
thanks
Old Feb 27, 2006 | 01:56 AM
FPGSXR's Avatar
RIP crunchy929.
Old Mar 2, 2006 | 05:32 AM
exx's Avatar
exx
RIP crunchy929.
Precious in the sight of the Lord is the death of His saints. (Psalms 116, Verse 15).
vanhaman
Aug 15, 2010 06:09 PM
tricksta1984
May 25, 2010 10:20 AM
whiteflash
Feb 4, 2009 07:49 PM
cammelo
Apr 3, 2006 04:02 PM
