Electrical trouble
Old Apr 10, 2011 | 01:43 PM
Drippps's Avatar
Default Electrical trouble
My headlights (low or high...doesnt matter) and my blinkers are not working! I took apart the switch and fuse...no issues that I could identify. My rear brake light is working fine. Horn works fine.
Any ideas? are there any in line fuses anywhere?
Old Apr 10, 2011 | 02:56 PM
Sunfly's Avatar
There was a post about this somewhere earlier. I had the same problem plus my guage lights were out too. For me it was the grey plug under the faring where all the wire bundles go into, just under the throttle. Plug was just loose.
Old Apr 10, 2011 | 08:31 PM
Drippps's Avatar
that plug looked ok....this is so odd. I will add that i recently went to LEDs in teh front and rear. everything was working fine for a few rides and now i have no blinkers or headlights.
I had a blown fuse at one point and I replaced that.
my gauges are all working fine.
I am thinking i have a short/ground issue at one of my connections. Ill have to pull apart all the nice wiring i did and start over.
Old Apr 11, 2011 | 07:47 AM
txsmainevent's Avatar
On the signals, try switching the 2 wires around...
Old Apr 11, 2011 | 06:51 PM
Drippps's Avatar
turns out it was that big grey plug, Sunfly! I unplugged it and plugged back in...BOOM...all back to normal.
Thanks!!
However, now my clock is flashing and wont stop flashing....it wont let me set it either...
Old Apr 11, 2011 | 07:04 PM
Thanks!!
Turn the key on without starting it. Press and hold both a and b buttons down until just the hour side is blinking. Change with b button and switch with a button. After set leave the bike alone. Don't turn it off! It will stop flashing and then you can turn the bike off/on.
Old Apr 11, 2011 | 07:10 PM
Drippps's Avatar
Yes...i know how to set it....the problem is...it is always flashing. When i turn the key to on...its already flashing and doesnt stop after 10 seconds....it just keeps flashing.
Pressing a or b button does nothing to the clock time (hours or mins).
Pressing and holding both doesnt do anything, especially let me set the clock.
So I will try disconnecting the fuse and battery tomorrow.
Old Apr 11, 2011 | 09:17 PM
Mine does the same, I can set it and after I kill the bike it resets. Im sure its a loose wire in the harness. I just cleaned my harness with wire cleaner so when I get it back together we will see.
Old Apr 11, 2011 | 11:02 PM
vwmaniacvr6's Avatar
Isn't there a separate fuse for the clock so that it keeps time when the ignition is off? Maybe that is blown and causing issues. I could be thinking of a different bike though...
Last edited by vwmaniacvr6; Apr 11, 2011 at 11:03 PM. Reason: I can't spell fuse right the first time.
Old Apr 12, 2011 | 08:01 AM
Naw not that im aware of. I pulled my plugs when i took mine apart to notice corression. Hopefully i get my damn clock back! My trip report also reset after the key was turned off. Ill find out soon. The bike is going back together as we speak.
