Cranking engine w/o spark plugs
no need to drain the fuel or remove the pump completely jus lift the tank. remove the pressure line to the fuel rail and th return line from the fuel pressue regulator and disconnect the wires to the fuel pump so it doesn't activate and u should be good to go.
