clutch adjustment problems
Old May 11, 2009 | 04:37 PM
davrosxuk's Avatar
Default clutch adjustment problems
hello folks... I wonder if anybody out there with a 929 would check the position of the clutch release lever (the little arm thing with a spring on it where the clutch cable attaches on the gearbox) after the slack has been taken up. Mine is at 90 degrees to the cover exactly pointing across the engine. the reason I,m asking is because I ran out of adjustment at both ends of the cable so I bought a new cable and it uses all the adjustment exactly the same as the old one??? The bike only has 15,000 miles on the clock....surely the clutch plates could,nt of worn so much already....there is no evidence of clutch slip but the free play at the handlebar end is becoming excessive with no adjustment left.......any ideas???? cheers dave h
Old May 12, 2009 | 07:53 AM
packdog's Avatar
it's worth a look at the clutch plates... mine has about that on the odometer and my plates were on the border of spec. go grab a cheap vernier caliper from harbor freight and measure the plates. outside of skinned plates, you may have a fracturing/fatiguing shift lever. I've seen elsewhere people have their lever literally bending over time until one day it snaps and you can't shift. good luck.
Old May 12, 2009 | 02:10 PM
davrosxuk's Avatar
cheers packdog.....err....whats a shift lever???? I havent heard that term before
koalaboy
Jul 9, 2012 06:16 AM
MoOdiR
Jun 14, 2011 10:35 PM
Turbulenz
Apr 13, 2010 10:15 PM
asides
Apr 5, 2010 07:02 AM
sc929
Sep 27, 2007 05:57 PM
