Clock
Old Nov 15, 2007 | 09:52 AM
BigMike0147's Avatar
Default Clock
Ok. I know this is probably a dumb question, but how do you reset the clock?! [&:]
Old Nov 15, 2007 | 11:21 AM
mark5009's Avatar
Default RE: Clock
Search is your friend ...
Simple start .. hold down both buttons, left slightly before right, for 3 sec. Right button to go from hrs to mins. Left to change values (or the other way around .. I forget). When set, leave.
HTH
Old Nov 15, 2007 | 12:17 PM
lexiconby's Avatar
Default RE: Clock
Engine Start button to On. You don't need to start engine. Press both buttons until clock starts blinking. If you press one button before the other and suddenly see mph to km/h or F to C on temperature, then you didn't do it correctly.
Did you figure out how to reset trip meter, going from mph to km/h and temperature from C to F? That's probably not as hard to figure out as setting the clock.
Old Nov 15, 2007 | 12:22 PM
Default RE: Clock
Thanks guys! I'll give this a shot when I get home. I kinda played around with it yesterday and reset my trip on accident. Really sucked because that's how I watch my gas. Anyhow, thanks for the knowledge!
Old Nov 15, 2007 | 02:31 PM
mark5009's Avatar
Default RE: Clock
Good luck, Mike ..
Even knowing what to do I still reset my trip the other day, and I do the same as you -- tripA is the fuel gauge. One of the joys of the 929.
Old Nov 16, 2007 | 09:44 AM
Default RE: Clock
Yep! And Trip B is the "oil gauge"!
gary951000f
May 21, 2010 03:46 PM
Sagerkillz
Oct 23, 2009 01:11 AM
cerojohn
Oct 14, 2008 10:45 PM
niskyne
Sep 26, 2006 10:51 AM
