CBR 929 all gunked up, I need some advice.
Old 11-23-2005 | 10:14 PM
lsu.tiger's Avatar
Default CBR 929 all gunked up, I need some advice.
I just got back from a tour in Iraq and my 929 has been sitting for about 18 months without even being started. After I replaced the battery, it ran, but not good. It sounded a little choppy and eventually got worse. My throttle response got really slow and now it won't even start. I put a little fuel additive in while it was still running and it didn't help at all. I've got some new spark plugs, but no wrench to install them (I discovered that I need a special wrench). I'll be tracking down a spark plug wrench, but does anyone know anything else I can do in the meantime?
Thanks
Old 11-23-2005 | 10:22 PM
NINE2NINE's Avatar
Retired Mod
Default RE: CBR 929 all gunked up, I need some advice.
if you have the original tool kit, there is a wrench in there that is designed for the spark plugs. sounds like you're going about it right. another thing that i would do is drain the fuel tank and put some fresh gas in.
Old 11-23-2005 | 10:27 PM
libretto's Avatar
+ 1 on the fresh gas i have a cr500 i left the gas in over the off season one time, it had almost turned into muck it was all in the tank and carb. Change the gas and plugs and you sould be good to go
Old 11-24-2005 | 01:36 AM
lsu.tiger's Avatar
Thanks! I'll try it. Do you guys change the plugs from the top or side?
Old 11-24-2005 | 02:23 AM
Chevota904's Avatar
Thats about it....if it still lags then you have more serious problems
Old 11-24-2005 | 03:34 AM
NINE2NINE's Avatar
Retired Mod
here's a link for another post on changing plugs. https://cbrforum.com/m_26897/tm.htm i can't offer advice on the subject. i heard that it was a pain in the butt to change the plugs so i had my dealer do it along with some other stuff.
Old 11-27-2005 | 01:49 AM
lsu.tiger's Avatar
I changed my plugs from the top instead of going behind the radiator. I had to use a spark plug socket, 4" extension, universal joint, and another 6" extension. I was able to get around the crossbar pretty easy. Aside from the pain of removing the fuel tank and air intake, it wasn't too bad.
As for the bike, changing the plugs definitely worked. It ran really weird for about 10 or 20 seconds, then smoothed out. When it smoothed out, I had the warning light come on for the fuel injectors (the "FI" on the display). I'm not sure what's up with that.
If you guys have any advice for this, I'd appreciate it!
Old 12-02-2005 | 08:06 AM
NINE2NINE's Avatar
Retired Mod
your computer probably adjusted the fuel injection for the bad plugs. when you installed the new plugs, your fuel injection needs were way off and probably tripped a sensor. this triggered the warning light. i would let it run a little and see if your computer re-compensates back to normal fuel injection settings and the light goes off. if not, take it to a dealer and have them hook up a diagnostics reader and see what codes that it is throwing off for. it might just need to be reset. i have no idea if i am right, but i have run into similar problems on a truck that i used to own.
rrasco
10-06-2010 12:58 PM
elrocky
06-23-2009 09:24 PM
07white600rr
03-06-2009 10:47 PM
city worker
11-10-2007 12:04 PM
txridder
12-02-2006 03:37 PM
