bumble bee chargeing problems
Old Mar 27, 2008 | 06:42 AM
shrek's Avatar
Default bumble bee chargeing problems
ok got it running plugs were fouled but the bike died on me I just replaced the stator yesterday and the sob died on me today could it be the regulator rectifier.
Old Mar 27, 2008 | 09:07 AM
Evan's Avatar
Default RE: bumble bee chargeing problems
You may need to charge up the battery first and run it. If you only let it run for10min ata time you might not charge up the battery enough. It's more than likely dead becausethe plugs being fouled and trying to start it.
You have three threads of the Bumblebee.....we need pics of the poor thing!
[sm=Flahssssss.gif]
Old Mar 27, 2008 | 12:47 PM
shrek's Avatar
the bat. was charged i started it and road it 5 miles before the power died and the bike shut down on me durring a curve and made me drop it. im trying to put pics. but it keeps telling me that the file is to big
Old Mar 27, 2008 | 01:21 PM
Evan's Avatar
That would be a little different. Don't run up the bank account too much in one month!
Old Mar 27, 2008 | 04:28 PM
bravehart's Avatar
ORIGINAL: shrek
so you have no power at all? when my stator went bad it still ran but the light and all were very dim.
Old Mar 27, 2008 | 05:44 PM
shrek's Avatar
no when the power whent out the bike died. the bat. slowly started charging back up but not enough to start it
Old Mar 27, 2008 | 09:59 PM
bravehart's Avatar
im trying to understand you,the engine stalled and would not restart?
you did remember to replug the stator harness. check where the bat. grounds into the chassis. make sure all your electrical connections are tight and clean.
if you have a muti meter i can tell you how to check.
Old Mar 28, 2008 | 06:17 AM
shrek's Avatar
Right the bike just lost all power and did not start back up I plugged the stator up. I will check the grounds and all the connections are tight and clean. If I can’t find the problem ill probably just take it in to the shop. I just hate to do that i've managed to fix ALL the other problems with the bike. I’m telling you if I could find another bike that handled like the 929 and had the power id trade. But I can’t so I guess ill keep dumping money into her. After I check the grounds how can I check if it is working right without riding it around and waiting for it to die on me? I do have a multi meter
Old Mar 28, 2008 | 12:17 PM
KidCr3nshaw's Avatar
Dude - your problems sound EXACTLY like mine.
In my haste to reassemble the bike for warm weather, I forgot to connect one of the two connectors to the rectifier.
Brand new battery dying in a day and a half - got maybe 8 starts out of the bike before kaputz. I would lose instrument cluster, then I would have to fight the idle to keep the bike running - if I had a nice straight, no problem. But if I was in traffic faggedaboudit.
Take your seat off and double check that you have BOTH connectors connected. They're both covered by that dust cover so it can be pretty easy to overlook...
At least that's what I tell myself to make me feel better. Give it a shot.
Old Mar 28, 2008 | 04:05 PM
bravehart's Avatar
i guess you need to charge your batt. well enough to power the bike for a few minutes. disconnect your stator plug/ harness. start your bike, you may need a 2nd person but you need to hold the rpms at 5k. take your multi meter an setto readfor ac amps. touch two of the threeleads on the stator plug, and you should get about 65-80 amps i believe, give or take alittle. check all theleads with each other(3 combinations). if its reading like 15 -20 amps then you know the stator or the rotor is bad. if the amps are high thenits problely your rectifier
blacken77
Jul 18, 2013 02:10 AM
shrek
Mar 27, 2008 04:18 PM
shrek
Feb 9, 2008 06:29 AM
justin8417
Nov 20, 2007 01:44 PM
Nevada Fred
May 1, 2007 01:54 PM
