BRAKES?????
Old Apr 2, 2007 | 08:25 PM
bignibb's Avatar
Permanent ROTM Nominee
Default BRAKES?????
well my bike was making a funny noise kind of a light humish sound when I presses on the front brakes so I assummed it was telling me 'hey you need new front brakes' but when I pulled the calipers off to check and change them, I found that the pads where in pretty good condition, actually they showed almost no wear.
the pad that I removed were the HH stintered EBC pads, which I thought were in the top of line of pads and the rear brake pad which made no noise, was almost at the metal!!!
so are EBC pads good pads for everyday riding?
I replaced them with a complete set of kevlar pads, are these type of pads any good? as good as the EBC Hh pads, are they better? are they junk?
or does any of this matter?
Old Apr 4, 2007 | 04:53 AM
Dluv35's Avatar
Default RE: BRAKES?????
did they hummm when they were hot? ebc is a good brake company. the more high performance pads will make noise if they are not warm cause they are prepared for harsh conditions.
Old Apr 5, 2007 | 01:17 AM
bignibb's Avatar
they only hummmmmed when I put them into a hard brake, not a gradual slow down?!
Old Apr 5, 2007 | 12:28 PM
esir_spd's Avatar
I also put on EBC HH pads and I get the same type of noise. I can hear it a little bit when cruising but it gets louder the harder I brake.
Old Apr 5, 2007 | 05:28 PM
Dluv35's Avatar
what rotors are you running?
Old Apr 5, 2007 | 06:00 PM
esir_spd's Avatar
I am running stock rotors.
Old Apr 5, 2007 | 06:08 PM
Dluv35's Avatar
that might be a reason for the noise, if its like cars you have to have rotors that compliment the pads, if they are high performance pads. my buddys g35 squeals like crazy because of his pads and rotors. they are aftermarket and meant for extreme conditions, if they arenot hot they sound like they need to be replaced. I wish I knew a lot about this subject but just givin my two cents because i was told not to upgrade just the pads, supposed to do everything, pads, rotors, lines. hopefully it makes sense. also no one else replied so i figured my advice might help some.
Old Apr 5, 2007 | 07:44 PM
esir_spd's Avatar
The bike stops fine, the wheel spins ok too. I bought the EBC HH's from the Honda dealer,I did ask them if the more aggressive pads would be bad for the stock rotors and they said it wouldn't be a problem.
Nytmr
Dec 21, 2013 09:16 PM
CBRInfantry
Feb 7, 2011 09:42 PM
hopz
Jun 4, 2009 01:28 AM
radvoem
Dec 28, 2008 08:38 AM
