axle spacers
Old Aug 12, 2008 | 04:35 PM
garnett62's Avatar
Default axle spacers
I recently removed the rear tire off my 01 929 and the axle spacers fell out. i need to know which one goes on the sprocket side and if there is a proper way to insert the other on the other side of the wheel? One of the spacers has a lip or edge around it, what side does it go on?
Old Aug 12, 2008 | 05:36 PM
rep929's Avatar
Default RE: axle spacers
the spacer with the lip goes on the sprocket side with the lip facing the swing arm
Old Aug 12, 2008 | 05:52 PM
garnett62's Avatar
ok, so the one with the lip is on the sprocket side, does it matter how the other spacer goes in or is it the same on both sides of the spacer?
Old Aug 13, 2008 | 12:42 PM
rep929's Avatar
does not matter
Old Aug 13, 2008 | 01:20 PM
RCR's Avatar
RCR
I hate that when you take something apart and a couple of pieces fall to the floor..[:@]
Old Aug 13, 2008 | 03:42 PM
garnett62's Avatar
thank you so much
lowcel
Jan 12, 2014 07:47 AM
notny41
F3 Wanted
Nov 17, 2011 11:03 PM
