for all who will ask tomorrow!!!!
Old May 17, 2007 | 08:35 PM
bignibb's Avatar
Permanent ROTM Nominee
Default for all who will ask tomorrow!!!!
e Configuration
Inline Four, 4-Stroke, DOHC
Engine Displacement
929cc
Engine Cooling
Liquid
Compression Ratio
11.3:1
Combustion Chamber Design
Pentroof
Valves Per Cylinder
Intake Valves Per Cylinder
Exhaust Valves Per Cylinder
Bore x Stroke
74 x 54 mm
Claimed Peak Horsepower
150 bhp @ 10,500 rpm (at crankshaft)
Claimed Peak Torque
76 lbs. - ft. @ 9000 rpm (at crankshaft)
Measured Peak Horsepower
130.6 bhp @ 10, 750 rpm
Measured Peak Torque
69.1 lbs. - ft. @7750 rpm
Measured Power To Weight Ratio
3.38 Pounds per Horsepower
Engine Redline
11, 500 rpm
Valve Angle (Included)
25 degrees
Combustion Chamber Volume
22.6 cc
Valve Train Type
DOHC, Link-plate Chain Drive,
Bucket Followers, Shim-under-bucket
Lash Adjustment
Valve Adjustment Interval
16,000 miles
Intake Valve Diameter
29.0 mm
Exhaust Valve Diameter
24.0 mm
Intake Valve Stem Diameter
4.5 mm
Exhaust Valve Stem Diameter
4.5 mm
Intake Valve Maximum Lift
8.6 mm
Exhaust Valve Maximfum Lift
8.2 mm
Intake Valve Timing
Open BTDC
25 degrees
Close ABDC
35 degrees
Duration
240 degrees
Exhaust Valve Timing
Open BBDC
20 degrees
Close ATDC
40 degrees
Duration
240 degrees
Valve Timing Measuring Point
Intake, 1.16 mm; Exhaust, 1.24 mm
Fuel Delivery System
Kehin Fuel Injection
Throttle Body Venturi Size
40 mm
Air Filter Type
oem
Exhaust System Type
Four-into-two-into-one with HTEV
Ignition System
Kehin Digital Electronic
Lubrication System
Wet Sump
Oil Capacity
4.2 quarts (4.0 liters)
Fuel Capacity
4.8 gallons (18.0 liters)
Transmission Type
6-speed, Constant Mesh
Clutch Type
Multi-plate, Wet
Clutch Actuation System
Cable
Clutch Spring Type
Coil
Number Of Clutch Springs
Number of Clutch Plates
17
Drive Plates
Driven Plates
Primary Drive
Gear
Primary Drive Gear Teeth (Ratio)
48/ 73 (1.521:1)
Final Drive Sprocket Teeth (Ratio)
16/ 43 (2.688:1)
Transmission Gear Teeth (Ratios)
6th
25/ 21 (1.190:1)
5th
27/ 21 (1.286:1)
4th
28/ 20 (1.400:1)
3rd
32/ 30 (1.600:1)
2nd
29/ 15 (1.933:1)
1st
35/ 13 (1.692:1)
Transmission Overall Ratios
6th
4.864:1
5th
5.256:1
4th
5.722:1
3rd
6.540:1
2nd
7.901:1
1st
11.003:1
Old May 18, 2007 | 03:17 AM
the greeen lantern's Avatar
Default RE: for all who will ask tomorrow!!!!
lol
i wonmder how much mechanical info we can pump into this one thread
Old May 21, 2007 | 08:34 PM
QuinC's Avatar
manual says its 3.9 liters of oil with filter change.
Old May 21, 2007 | 09:07 PM
jcowick's Avatar
yeah get it right
Old May 22, 2007 | 12:16 AM
bignibb's Avatar
don't try to correct what doesn't need correcting!!!
At drainning 3.5L (3.7 US qt, 3.1 Imp qt)
at disassembly 4.0L (4.2 US qt, 3.5 Imp qt)
at oil filter change 3.7 (3.9 US qt, 3.3 Imp qt)
and that is from the manual!!!!
Old May 22, 2007 | 12:32 PM
Triax's Avatar
just thought I'd add tire sizes
FRONT 120/70ZR 17
REAR 190/50ZR 17
Old May 22, 2007 | 03:33 PM
Illushun's Avatar
Acceptable ohm resistence of the 3p natural wiring for the stator and rectifier is .01 ~ 1.00
My stator just went on me so I replaced it based on that info.
This tests and verifys if your stator or rectifier are working or within acceptable electrical tolerances.
kawiman
Aug 11, 2010 10:19 PM
MarkF3
Mar 24, 2009 02:03 AM
jdschmidt
Jul 10, 2008 09:26 AM
skitzofrenzy
Apr 16, 2008 08:32 PM
jdschmidt
Apr 11, 2008 10:14 AM
