929rr strange issues
I purchased a 2001 929 4 months ago and absolutely love the thing (until yesterday). I had the bike down to replace fork seals and neck bearings for the last cpl days and while reassembling found a loose ignition wire that I soldered back on. Got the bike started yesterday and it ran like crap (wouldn't hardly pull itself) and I felt it had fouled a plug (replaced plugs 400 miles ago) so I pulled the plugs and found no issues there. I put it all back together and the problem is worse, won't start at all and flames out the exhaust. I consider myself pretty mechanical, I just don't have much experience with this bike. I do have the manual and I didn't see much there. I'm thinking it is either ECU or ignition related. Any help is appreciated.
And running rich. Mine does this after I had the valves adjusted. (which I highly reccomend doing at the appropriate mileage) The timing chain and tensioner were also changed...and my bike is as rich as Scott Pioli! I'm getting ready to put a PCIII on, and have it tuned...you may want to do the same, especially if you have an aftermarket exhaust...that's normally the main culprit on these 929's.
![Icon Hyper](https://cbrforum.com/forum/images/smilies/icon_hyper.gif)
