929 upgrades?
RE: 929 upgrades?
how is people are able to do the running lights with the headlight shut off? how does that work...im gonna do that led blinker in the headlight and a custom led light setup along the fairing line in the front to be a part of the flush mount turn signal setup...as for power ill look into the bmc as long as it is the lifetime guarantee like k&n and the PCIII, possibly a little NO2 if the need calls for more speed on the top end...seeing how i have all the hook ups from my purge setup...would just need jets in the intake and so forth...what you all think about nitrous?
RE: 929 upgrades?
Boosted: Are you a racer??? Not really sure when a little more on the top end is really needed.
Everyone else: Thanx for you comments. I'm a weekend warrior myself, so I've basically stayed stock on the performance side. Tying in comments from the other threads, it seems that a sprocket change (just the font) seems like the easiest thing to do for a bit of "Uummfh" on the low end. Since I only have an Erion slip-on, I've debated on whether or not to install a PCIIIr. I'm mainly a canyon rider and since Firestorm 2007 has us guys in San Diego on hold, I'm starting to get that itch to upgrade. You guys think it's worth a PCIIIr for low and mid range for a weekend warrior???
RE: 929 upgrades?
the only link i've found for those corner lights was the one i posted. if you happen to find a better one let me know. I have yet to do it to mine but it seems fairly simple to do, only thing is i havent found a led bulb that you can mount without having to remove the lens. they all need a nut to go on from the inside to hold it in place
RE: 929 upgrades?
im not to worried about removing the lense...thats easy...what about having the crystal clear housing converted over to a black housing? i want to try and have a blacked out look but the headlight really stands out...i dont want to cover it with a tint but rather get the housing itself coated in order to be black but still be as clear as day through the lense...
