929 problem
Old May 5, 2022 | 03:06 AM
Trifke954's Avatar
Default 929 problem
I rebuild this engine in my 929 rr, 954 engine, and there's some noise between 3000 and 5000 rpms, also when decelerate, sound is there
https://m.youtube.com/watch?v=iTColXegM20
Cct looks good, what else can be a problem? Clutch basket is little noisy on idle but doubt that she is the problem
Old May 11, 2022 | 02:11 PM
Leeroy Jenkins's Avatar
Hi Trifke954,
Sounds like a chain to me.
How is the tension?
Maybe you can hold the chain while rev'ing to see if the sound stays?
Has the 954 engine been overhauled?
Cheers,
Leeroy
Old May 11, 2022 | 02:26 PM
Trifke954's Avatar
Originally Posted by Leeroy Jenkins
Hi Trifke954,
How is the tension?
Cheers,
Leeroy
Engine was sleeved and reassembled, how do you think to hold chain? Cct working but maybe is spring lost tension and cct cant extract all the way out
Also i try to find out with screwdriver on my ear,source of noise, and it is a pretty damn loud on right side engine, where chain was located, i have diy manual tensioner, just need time to replace it, and see if there is a difference
Old May 15, 2022 | 05:57 AM
Trifke954's Avatar
Thinking, i might find a problem
Clutch should not make this rattling noise right?
Old May 15, 2022 | 06:58 AM
Trifke954's Avatar
Nope, engine started without clutch plates and noise is still there, so i inspect cam chain, it's a bit strange, left side of chain where cct goes is tight, but other side is a bit lose 🤔
Old Jun 14, 2022 | 03:11 PM
Trifke954's Avatar
Problem solved, cam chain was stretched
Old Jun 14, 2022 | 03:21 PM
Interesting, thanks for the follow up. How did you determine that the chain was stretched? Did you lay it side by side with a new one? How much different were they?
Old Jun 14, 2022 | 03:28 PM
Trifke954's Avatar
I saw it when i removed cct, it was extracted all the way and there was no resistance when i removed bolts, like it should be
Old Jun 14, 2022 | 03:47 PM
Nice, glad it's fixed. Enjoy the ride.
Old Jun 14, 2022 | 04:00 PM
Trifke954's Avatar
Thanks man 💪🏻
I got few errors, code 9 and 35
​​​​Iat sensor and exhaust valve but both are working fine, iat is in spec, probably dirty air filter.. I will replace it soon as I find it
Gleason
Oct 7, 2020 12:14 AM
Monstrosity
Oct 8, 2009 09:44 PM
nicks929
Apr 17, 2008 04:36 PM
TWJ
Sep 4, 2006 02:31 AM
