2000 CBR929RR ecu issues
Old Jul 29, 2022 | 05:26 AM
Courtneyccarver's Avatar
Default 2000 CBR929RR ecu issues
Hey y’all I got a 2000 CBR929RR that needs a ecu but having a hard time finding one. Does anyone know if any other year bikes, the ecu would work from?
Old Jul 29, 2022 | 10:07 AM
dannoxyz's Avatar
You can probably use ECU from 2001 CBR929RR.
But no other ECU from different model will work. Programming is so different, it will blown up your engine.
What kind of issues are you having?
Old Aug 3, 2022 | 04:22 PM
Its only firing on number 3 and 2 cylinders, number 1 and 4 won’t fire when you start the bike but will fire if being tested. It’s at the Honda shop right now they said they tested everything and it’s leading them to the ecu cause nothing else seems to be wrong
Old Aug 4, 2022 | 09:33 AM
dannoxyz's Avatar
ECU failure is extremely rare, only seen 1 in over 40-yrs of riding and owning over 30 bikes.
Most likely it's some sort sensor that's out of spec or mis-adjusted. Crank/cam sensor most likely. Also wiring and corroded connectors are common. We'll see what shop finds, if they're any good. Oscilloscope most handy tool, doubt anyone there knows how to use one to fix in 5-minutes.
Weapon929
Sep 16, 2021 07:14 PM
gotama
Dec 11, 2011 12:36 PM
rcmadawala
Jul 8, 2010 05:48 PM
Aldebaran
Jul 12, 2007 06:59 PM
bigwal
Mar 31, 2007 05:18 PM
