2000 929 Overheating
Old Sep 12, 2009 | 10:59 PM
Jenocbr's Avatar
Default 2000 929 Overheating
Hi, I am new this this forum. I recently bought a 2000 929. It has been running great for the past 2 month then all of the sudden when i riding in the city, the bike started to run hot, 234F but the fans did kick on. I stopped the bike and parked it. Coolant was coming out of the top of the smaller radiator hose on the right side of the bike under the cap that leads to the lower part of the fairing. I added more coolant in the radiator and the same thing happened. I drained the fluid and the same thing happened again but every time it does it, the temp on the gauge reads under 230F. What do you think the problem is?
Thanks,
Jeno
Old Sep 29, 2009 | 02:39 AM
scaredem23's Avatar
this might sound stupid since i'm not really technical with bikes but ill throw this one out there anyway. Could it be your thermostat is malfunctioning?
Old Oct 6, 2009 | 08:53 PM
929 RR CBR's Avatar
if the fans are comming on it could be the thermostat or i could be a bad water pump possibly, or mabey a clogged radiator.
Old Oct 7, 2009 | 02:51 AM
scaredem23's Avatar
So that wasnt such a bad suggestion eh? I'm learning more and more on this site.
Old Dec 13, 2009 | 06:22 PM
jloshotz's Avatar
Also check to make sure your rad cap isn't blowing off prematurely.....could be as simple as that
6rush6
Jul 8, 2024 08:23 AM
J187
Sep 7, 2010 04:01 PM
Renegizzo21
Aug 19, 2008 11:13 AM
nlparry
Sep 12, 2007 08:22 PM
