2000 CBR600 F4 overheating, replaced thermostat already
So, I had been meaning to change the plugs anyway, so while I was in there I figured I would swap out the thermostat considering it was cheap and simple to do, it didn't solve the problem however.
Here's what's going on.
This leaves only two possibilities right? One being the thermo switch and the other the fan motor? Is there a good way to test the thermo switch? I read something about jumping two leads together, but this switch only has one lead...
This is the switch
- Bike will reach red temps and overheats.
- Fan does not come on
- Fan fuse is good
- Thermostat is brand new
This is the switch
Stupid question but you have checked the coolant level?
If you want to test whether the fan works just pull the lead off the thermo switch and short it to ground. If the fan cuts in then you know it's the switch. If it doesn't and you've definitely got voltage on the lead then the fan motor is shagged.
They jump up real fast when setting idle in traffic, especially when the fan doesnt run. The switch is basically a normally open switch and when it reaches temp it closes and gives the fan the ground it needs. As long as you have power to the fan then just unplug the wire from the switch and ground it with the key on and it should run. If it doesnt check you have voltage on the positive wire. Its not uncommon for the fans to die on these bikes.
