00 929
Old Apr 13, 2005 | 09:31 PM
gofast!'s Avatar
Default 00 929
Hey new to the forum and just wanted to say whats up. I am looking for information on the best low cost mods for the 929. I already have a Micron full exhaust, and 16T Front sprocket, 45T rear sprocket. Any help from the pros out there would be appreciated.
Old Apr 18, 2005 | 09:13 AM
gofast!'s Avatar
Default RE: 00 929
I guess nobody wants to helpa brotha out? Trying to get info and input on mods that I can do myself......anyone----??
Old Apr 18, 2005 | 06:35 PM
YellowRR's Avatar
Default RE: 00 929
Hello and Welcome
To add to your bike you can go with a BMC race air filter. These filters flow more than stock filters and are reusable. Installation takes about 10 minutes if you have the fairings off.. I noticed a smooth acceleration and quicker throttle response. The two versions are race and street. The race version requires mapping (pc3) because of the increased airflow.
http://www.bmcairfilters.com/infoBK2.asp
The flapper mod is a good mod as well. Here is an explanation, for a 954 but same principle for 929:
http://www.fireblades.org/forums/showthread.php?t=11138
Good Luck.
YellRR
Old May 21, 2005 | 12:29 AM
johndoe's Avatar
Default RE: 00 929
my first mod was a scotts steering damper. well worth the money.
Old Jun 2, 2005 | 02:53 AM
Calkidd's Avatar
Default RE: 00 929
ORIGINAL: YellowRR
The farings have nothing to do with changing your air filter. All you have to do is prop up your gas tank.
Old Jun 2, 2005 | 11:26 AM
jeff929's Avatar
Default RE: 00 929
I have been doing a lot of mods on my 929 but not for speed because we all know it really is fast enough
I started with new seat then new bars with weighted inserts with spider grips and boy what a differance
New pegs really helped and then a taller windscreen
The only real perforance parts I added was to totally upgrade the brake system with new pads brake lines and high grade
brake fluid.
[8D]
