Wheels
Old Nov 9, 2006 | 08:14 PM
JSTATL's Avatar
Default Wheels
Will wheels from a 1996 CBR900RR fit a 99?
Old Nov 9, 2006 | 08:23 PM
woody900rr's Avatar
Default RE: Wheels
Front will not fit (98-99 rr's have wider fork setup than the 93-97) If the shims and rotors from 99 are used the rim will fit the front. Plus 98-99 rr's have bigger rotors on them thus the caliper mounts have been moved up on the fork bottom. If the bike has forks from a different year pre 97 the rim will be a direct bolt in.
The rear rim should have no problem as long as the 99 sprocket holder, cush drives and axel/shims are used. 98-99 swing arema are slightly different (chain adjusters are located in a different spot than the 93-97 years).
Old Nov 10, 2006 | 03:09 AM
JSTATL's Avatar
Default RE: Wheels
so what your telling me is that the front rim should bolt right up if i use the 99's rotors and the rear should bolt right up if i take all the parts from the 99 rim off and put them on the other rim
Old Nov 11, 2006 | 07:54 PM
woody900rr's Avatar
Default RE: Wheels
True...
DragonCBR
CBR1000F For Sale / Found
Mar 3, 2013 03:25 PM
Gotpepsi
Apr 29, 2011 09:25 AM
jordan
May 28, 2006 06:57 AM
energycontacts
Apr 27, 2006 03:06 AM
