Wheels
RE: Wheels
Front will not fit (98-99 rr's have wider fork setup than the 93-97) If the shims and rotors from 99 are used the rim will fit the front. Plus 98-99 rr's have bigger rotors on them thus the caliper mounts have been moved up on the fork bottom. If the bike has forks from a different year pre 97 the rim will be a direct bolt in.
The rear rim should have no problem as long as the 99 sprocket holder, cush drives and axel/shims are used. 98-99 swing arema are slightly different (chain adjusters are located in a different spot than the 93-97 years).
